Footprint Expert: the Standards Used |
Post Reply |
Author | |
Nick B
Admin Group Joined: 02 Jan 2012 Status: Offline Points: 1929 |
Posted: 21 Oct 2024 at 9:30am |
IEC_61188-7 - Zero Component Orientation IPC J-STD-001 - Solder joint goals for Toe, Heel and Side IPC-7352 - Mathematical model for pad stack calculation FED Vol 18 - Proportional Land Dimensioning Concept The Footprint Expert uses these standards by default, however these and dozens of other options may be easily configured to build entire libraries to your own CUSTOM requirements! Any parts previously built/saved in the Footprint Expert neutral format can be rebuilt to any CAD format, with any modified setting. Default rotation? Change setting, batch-build! New tolerance? Change setting, batch-build! Different pad shapes? Line widths? etc... No problem!
Post Reply | |
Tweet |
