- Use the same package tolerances for all vendors, regardless of the datasheet specification.
- Use nominal package dimensions and hard code solder joint goals for Toe, Heel, and Side.
- Improved Manufacturing Precision: Modern machines and manufacturing processes for electronic components and PCBs are highly accurate, producing components and assemblies that closely adhere to nominal dimensions.
- Industry Standards: Most component manufacturers recommend solder patterns in their datasheets are based on Nominal package dimensions with pre-defined solder joint goals. Few use the IPC-7351 mathematical model, which incorporates manufacturing tolerances.
- Tolerance Variability: Component package tolerances differ widely between manufacturers, complicating footprint standardization. This raises questions about the necessity and accuracy of these tolerances. Are they practical and realistic?
- Obsolete Complexity: The IPC-7351 mathematical model, originally created in the 1980s, is overly complex for today’s technology. IPC uses the Maximum Material Condition for calculations, which often results in unnecessarily large pad stacks.
- European Standards Alignment: The European standards organization FED (www.fed.de) advocates using Nominal package dimensions for land pattern calculations. Rainer Taube, a member of the FED board of directors and founder of Taube Electronic in Berlin, published FED Vol 18 “The New Proportional Land Pattern Dimensioning Concept” in 2018 which calls for the use of Nominal package dimensions and terminal height percentages for pad stack calculations.
Additional Considerations
Chip Capacitor
![](uploads/1/nomCalc_ChipCapacitor_2025-01-05_18-21-56.png)
Chip Resistor
![](uploads/1/nomCalc_ChipResistor.png)
Chip Inductor
![](uploads/1/nomCalc_ChipInductor.png)
Polarized Chip Capacitor
![](uploads/1/nomCalc_PolarizedChipCapacitor_2025-01-05_18-23-10.png)
Chip Diode
![](uploads/1/nomCalc_ChipDiode.png)
Chip LED
![](uploads/1/nomCalc_ChipLED.png)
EIA Standard Chip Component Package Sizes with no Standard Height
reference
Table of Chip
Package Size Codes and Dimensions
EIA (inch) Name
Inch Dimensions
IEC (metric) Name
Metric Dimensions
01005
0.0157 in × 0.0079 in
0402
0.4 mm × 0.2 mm
0201
0.024 in × 0.012 in
0603
0.6 mm × 0.3 mm
0402
0.039 in × 0.020 in
1005
1.0 mm × 0.5 mm
0603
0.063 in × 0.031 in
1608
1.6 mm × 0.8 mm
0805
0.079 in × 0.049 in
2012
2.0 mm × 1.25 mm
1008
0.098 in × 0.079 in
2520
2.5 mm × 2.0 mm
1206
0.126 in × 0.063 in
3216
3.2 mm × 1.6 mm
1210
0.126 in × 0.098 in
3225
3.2 mm × 2.5 mm
1806
0.177 in × 0.063 in
4516
4.5 mm × 1.6 mm
1812
0.18 in × 0.13 in
4532
4.5 mm × 3.2 mm
2010
0.197 in × 0.098 in
5025
5.0 mm × 2.5 mm
2512
0.25 in × 0.13 in
6332
6.4 mm × 3.2 mm
2920
0.29 in × 0.20 in
7451
7.4 mm × 5.1 mm
EXAMPLE 2 - Gullwing Leads:
PCB Libraries, Inc. added the Nominal Calculation Mode to Footprint Expert V25.02 as an alternative land pattern calculator in January 2025. Users can switch back and forth between IPC-7352 and the New Proportional Land Dimensioning Concept.
Message from Rainer Thuringer, FED-Chairman
In addition to reliable components and circuit boards, reliable electronics require equally reliable production. Following assembly with a low placement tolerance, a flawless soldering process of the components is particularly important. This in turn requires that the pad stacks on the circuit board match the component terminals exactly.
The advantages of the New Proportional Land Dimensioning Concept are: - Easily scalable
- Trouble-free adaptation also for future components
- Risk, minimization (e.g. bridging and paste printing, best adapted paste volumes)
- Higher reliability of the solder joints (error-reduced assembly process)
- Proportional land pattern leads to more space for the PCB layout routing process
Purchase the FED Volume 18 publication here: |
