  New Posts New Posts RSS Feed - Error Making "Molded Body" Diodes
rdl86626 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdl86626 Quote  Post ReplyReply Direct Link To This Post Topic: Error Making "Molded Body" Diodes
    Posted: 13 Mar 2013 at 12:06pm
I tried to create a Molded Body Diode (0402) and got an error saying -
"Object reference not set to an instance of an object" with a bunch of figures upside down L's the & landpatterndate.
I used the template for Molded Body to start.
I have no idea what I did wrong  Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdl86626 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2013 at 12:15pm
I changed to rev 45 and it worked fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2013 at 12:17pm
But the current release is V47... and V48 will be released this week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdl86626 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2013 at 12:45pm
The current release V47 does NOT work, that's my problem.
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2013 at 5:52pm
The only one i seem to be having trouble with is the 'Chip' calculator. Thats been fixed by Jeff for the new version.
So you're saying when you click on the 'Molded Body' Calculator it gives you the garbage box?
Also, which tool are you trying to output to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2013 at 7:19pm
Can you post a URL web-link to the Molded Body component package datasheet?
That will help us reproduce your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdl86626 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2013 at 7:29am
Chris,
   It is before I out put to a tool, but the tool is Orcad or allegro. I get the garbage box clicking ok, after putting in all of the data. I did a screen shot but have no idea how to get it to you. It is a word document.
Thanks
   Tom,
This page was generated in 0.220 seconds.
