  New Posts New Posts RSS Feed - 0201 Capacitor Corner Radius Pad
dramos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Topic: 0201 Capacitor Corner Radius Pad
    Posted: 15 hours 43 minutes ago at 4:09am
Hi all,
I created my first 0201 capacitor and I feel that using a Corner Radius Size Limit parameter= 0.10 mm could be "risky" (I used Fab Tol= 0, Placement Tol=0).
I know that some manufacturers use 0.05 mm.
My component is GRM033R61C104KE14D from Murata
Which is your recommendation for this tiny component sizes?
Waiting for your comments.
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 22 minutes ago at 8:30am
Rule of thumb - any package less than 1.00 mm in length or width should have 0.05 mm corner radius pads.
You can use the 'SMD Pad Stack Rules' in the side panel of the calculator to change the corner radius.
Or you can move the calculator footprint to FP Designer to permanently save the 0.05 mm corner radius to FPX library format. But we recommend that you first setup everything in the calculator before moving to FP Designer so you won't have to edit the pad stack in FP Designer.
FP Designer saves all your settings to the FPX library. You can rename the Footprint Name in the Library Editor.
