Allow Padstack Edits |
Post Reply |
Author | |
caclark
Advanced User Joined: 24 Oct 2012 Location: Cincinnati, OH Status: Offline Points: 177 |
Posted: 04 Oct 2013 at 6:06am |
It is all well and good that you provide the ability to make a completely custom footprint/decal. However in my experiences It is much better served to let me build a base footprint/decal for a specific part family, but then allow me to do some basic things to this base footprint/decal like move, resize, and add individual pins as needed.
My case in point. I am currently creating a 3 pin SOTFL (On Semi DTC114EM3). So far every 3 Pin SOTFL I have created to date has a different size for pin 3 than for pins 1 & 2. So what I have to do each time is create the part with all 3 pins the same size, export it to my native tool and change pin 3 to the correct size. This works, but in say 2 years I then need to recreate this part for whatever reason. My saved library of this part still has all 3 pins the same size, I then better hope that I remember to once again resize pin 3. |
Admin Group Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5734 |
The PCB Library Expert has 3 options -
In the case of the SOTFL you listed, the FP Designer would be perfect to generate the exact footprint and save to FPX file. You can still change all of your drafting preferences for silkscreen, assembly, courtyard and 3D model line widths and text heights in the future and regenerate a new library, but the pad stack sizes and locations will never change. |
You can now convert Calculator parts to FP Designer to have 100% access to the Pad Stack Editor and Manager. Freely edit every layer of the pad stack and even rename the pad stack. |
Post Reply | |
Tweet |
