  New Posts New Posts RSS Feed - 3D STEP Model Polarity Dot Missing on SOICs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 35 minutes ago at 8:08pm
SOT 3D STEP models don’t have a polarity dot because the component manufacturers don’t have one on their physical packages.
Polarity Dots on component packages are intended for assembly shops to prevent inverting the component placement.
Packages that have odd pins where it’s impossible to invert the assembly attachment.
A 3-pin SOT23 does not need a polarity dot.
A 4-pin SOT143 can’t be inverted.
A SOT223 cannot be inverted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 31 minutes ago at 2:12am
Please provide more details for this note "Some 3D models may not support the polarity dot"
it added for all the packages below
it will be great if have document explains this point so i can be aware by this concept
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 16 minutes ago at 2:27am
also
