  New Posts New Posts RSS Feed - TO 92
TO 92
RonieRC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RonieRC Quote  Post ReplyReply Direct Link To This Post Topic: TO 92
    Posted: 08 Aug 2025 at 2:34am
How does the footprint Expert calculate the location of the pads/holes in TO92? Specially the Y location. Pitch is for the X location.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2025 at 7:50am
We've been using the same pattern since the 1980s.
Pin 1 & 3 are on a 2.54 mm (0.100") grid in the x axis.
The group of pins is centered in the component body to have equal distance from Pin 1 to the body and Pin 2 to the body and Pin 3 to the Body in the 'Y' axis.
However, you can place the pins 'In Line' with a pin pitch of whatever you want.
Either way, you're bending leads (lead forming) to fit in the holes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RonieRC Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 35 minutes ago at 12:12am
Im main concern is the y location. How Foot print Expert derived it. The information we only provided is the "E,D & b" . when I check the pin location it doesnt use the E. Instead of E=1.33 ( my input) .its 1.3075 . Please clarify
This page was generated in 0.187 seconds.
