  New Posts New Posts RSS Feed - TO 92
TO 92
RonieRC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RonieRC Quote  Post ReplyReply Direct Link To This Post Topic: TO 92
    Posted: 8 hours 43 minutes ago at 2:34am
How does the footprint Expert calculate the location of the pads/holes in TO92? Specially the Y location. Pitch is for the X location.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 27 minutes ago at 7:50am
We've been using the same pattern since the 1980s.
Pin 1 & 3 are on a 2.54 mm (0.100") grid in the x axis.
The group of pins is centered in the component body to have equal distance from Pin 1 to the body and Pin 2 to the body and Pin 3 to the Body in the 'Y' axis.
However, you can place the pins 'In Line' with a pin pitch of whatever you want.
Either way, you're bending leads (lead forming) to fit in the holes.
