  New Posts New Posts RSS Feed - Library Expert 2015.03 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2015.03 Released!!
    Posted: 21 Nov 2014 at 12:49pm
Version 2015.03 was just released!!
NEW:
  • Calculator:
    • New Radial Rectangular LED component family
  • User Preferences > Drafting:
    • Added an option to “Expand Courtyard to Include Silkscreen” - when unchecked, Silkscreen is allowed outside the Courtyard Excess
  • PADS Layout:
    • An option to set the Right Reading value for Ref Des Text has been added. Selections are None, Orthogonal and Angled. Default is Orthogonal.
FIXED / ENHANCED:
  • FP Designer:
    • Through-hole Footprint Names: Batch Create was not producing an _P for the footprint name environment suffix
    • Fixed a problem with slots where the offset of the pad was being added to the width of the pad. This bug applied to all translators.
  • Librarian:
    • When adding a new column and an existing header name was used, the error message would not close
  • Calculator:
    • LGA Lead Shape drop down had incorrect options
  • PADS Layout:
    • ‘Use Footprint Name and Part Number’ will only be selectable when building a part from the Library, as it uses the Library data as part of its function
    • Fixed a bug that was causing improper names to be generated if you changed parameters after a part generation
    • Use Footprint Name and Part Number will only ever be checked if the option is enabled
  • Altium Designer Scripting:
    • Updated the Script import to a double click option, Open Project and Run Script
    • All parts now automatically center themselves to the window after creation
    • Slotted Holes did not have a hole. Offset Pads for slots should also work properly now.
    • Introduced a combo Box option to set a Target Library
      • Create New: This option will automatically create the PCB Library for you. Use this if the parts you are creating are going to be the only parts in the library.
      • Use Existing: If you use this option, you must select a library to add a part to before running the CreateALibrary script. Use this option if adding the parts to an already existing library.
    • Fixed a problem where the solder mask swell for irregularly shaped pads wasn’t being displayed properly
  • 3D STEP Models:
    • Model Offsetting for parts where the origin is pin 1 rather than the body center now work properly so PCB Tools map the 3D model to the 2D footprint properly
    • Fixed an issue with some parts being 90 degrees off rotation
    • Fixed a problem with the leads for Shrouded Receptacles and Altium
    • Radial LED Rectangular Family now has a 3D Model
This page was generated in 0.406 seconds.
