  New Posts New Posts RSS Feed - Library Expert 2015.01 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2015.01 Released!!
    Posted: 31 Oct 2014 at 12:31pm
Version 2015.01 was just released!!
NEW:
  • Library Editor:
    • Added over 5,000 Case Code parts in SM, BGA & TH FPX (for customers only)
    • Updated Sample FPX with 235 parts
  • Altium:
  • PADS Layout:
    • Ability to use FPX “Footprint” column for Decal name and “Part Number” for Part Type name
    • Ability to only OLE import Decals (turn off Part Type export)
    • Ability to only OLE import Part Type (turn off Decal export)
  • FPX format for V2015:
    • An upgraded file format for FPX has been added. This file format can now store custom part data.
    • The default FPX file format is still V2012 and will only update to V2015 when a V2015 FPX file is added to any FPX file
  • Calculator:
  • FP Designer:
    • Silkscreen auto-trimming around pads
    • Pin Renumber
    • Select Pin and RMB select Reorder Pins and cursor will display pin name
  • Utility Tools:
    • PADS to CAD translator
  • User Preferences:
    • All SMD pad style now defaults to Rounded Rectangle shape
    • Users can change the default SMD pad style to whatever shape they want
FIXED / ENHANCED:
  • 3D STEP:
    • Added Molded Body Diode, Non-polarized
  • Allegro/OrCAD PCB:
    • The pins will be generated in two passes in the script now. First electrical will be placed, then mechanical will be placed. This fixes a problem where if the first pin was a mechanical pin, the script wouldn’t transition back to electrical pin placement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2014 at 12:34pm
As you can see, version 2015 is packed with quite a few goodies! If you want to upgrade from version 2014 (we highly recommend!), you can here: www.PCBLibraries.com/products/upgrade
Please contact us or your local distributor if you want to upgrade from a version older than v2014.
Regards,
Nick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2014 at 12:35pm
If you recently purchased the Library Expert and the v2015 upgrade option, you might need to update your key. To update the license on your key, please follow these steps: www.PCBLibraries.com/activatekey
This page was generated in 0.301 seconds.
