  New Posts New Posts RSS Feed - What's Wrong with Your Footprint?!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: What's Wrong with Your Footprint?!
    Posted: 31 Jul 2024 at 3:57am
The details below are just some of the differences (yes, there are more!) between the Footprint Expert footprints and the libraries available all over the internet. Most don’t realize how lacking all those footprints online really are, but they can be much worse than lacking when they actually cost you money.
Footprint Expert
Source 1
Source 2
AUTO-GENERATED library parts use predefined or user-modified rules – share across your organization;
RULES-based, auto-generated part library
MANUALLY CREATED by many different people, using countless rules – results in a board with inconsistently built parts, far more prone to introduction of costly errors; massive variations in parts inconducive to standardized rule-based library
Built to exact datasheet specification, either Metric or Mils
Units vary based on source, and Metric often converted from Mils with rounded-off measurements; converting pin pitch often results in leads not fully centered on pads
User-defined consistency of line widths for all parts
Many different line widths used across different footprints due to lack of standard rules
Accurate contour courtyards are auto generated
Sloppy or non-existing contour courtyards
Relevant data: Footprint Name, Physical and Logical Descriptions, datasheet link, and more
Nothing, or inconsistent random data
Auto-generated keep outs on all non-plated holes for copper poly shapes, traces and vias
Missing keep-out will cause DRC errors at the manufacturer if copper, traces, and vias are placed within 0.25 mm of the non-plated hole
Pin 1 polarity markers for silkscreen and assembly
Pin 1 markings missing or vary in shape and in size
Footprint Origin at center of gravity
Footprint Origins randomly placed
Uniform, silkscreen outlines are whole objects mapped to the maximum package dimensions
Silkscreen is fragmented and mapped to the nominal package dimensions
Clear, consistent, intelligently placed markings to minimizes use of board space
Inconsistent and extra markings and excessive courtyards require more placement space
Consistent silkscreen trimming around all pads
Inconsistent and random silkscreen trimming around pads
Solder Mask swell auto-applied and configurable
Inconsistent solder mask swell from one footprint to another
Through-hole pad stack hole sizes automatically defined by maximum terminal lead diameter, and pad size auto-calculated by 1.5 x hole diameter
Lack of published, consistent rules to define through-hole pad stacks make it impossible for proper quality control of resulting footprint, results in capriciously calculated footprints
Non-plated holes have smaller pad sizes to prevent copper slivers after drilling process
Non-plated holes have a pad size equal to the hole size create risk of copper slivers after the drilling process; the plane antipad is randomly defined with no obvious rules
The Footprint Expert automates footprints to perfection. Professional, detailed, and accurate parts – all built consistently with identical rules, regardless of how many people are involved in your library development.
Get your FREE Footprint Calculator or Footprint Expert Evaluation License:
Call us - 847-557-2300
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 12:13pm
The free Footprint Calculator and the Footprint Expert are compared here:
To download and use the free Footprint Calculator:
1. Login at https://www.PCBLibraries.com/downloads
(login with existing account, or register for free)
2. If you see this button, click it:
3. If you do not see it, you already have a Key. Click this button to download:
4. Install and run the Calculator, then use your Email and Key (full key displayed on Download page) to activate the Calculator license.
PCB Footprint Expert
Call:  847-557-2300
