  New Posts New Posts RSS Feed - build non standard Jedec BGA
ThomasHM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ThomasHM Quote  Post ReplyReply Direct Link To This Post Topic: build non standard Jedec BGA
    Posted: 27 Jul 2023 at 4:07am
Is it possible to create such non Jedec standard FPGA in Footprint Expert 23 Enterprise
From NXP called H-FC-PBGA-448 17X17X2.46 PKG 0.75mm Pitch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2023 at 8:29am
Yes, you can build this non-standard footprint using the FP Designer module and a .CSV coordinate file.
In Excel spreadsheet create column A as the Pin Name, column B as the Pad Rotation, column C as the X coordinate and column D as the Y coordinate.
Then import the .txt ASCII file and it will automatically place all the pins.
For more information on how to do this, contact me and off-line and I will provide instructions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ThomasHM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2023 at 12:55am
Perfect Thank You. I created that footprint within some minutes.
What is your recommendation to name such cell in Mentor Graphics we are usually follow the IPC naming convention.
I named it NXP_H-FC-PBGA-448
Clap
Best Regards and have a nice weekend.
Thomas
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2023 at 7:38am
Yes, the footprint name NXP_H-FC-PBGA-448 is perfect.
The footprint looks great! Good job.
This page was generated in 0.221 seconds.
