  New Posts New Posts RSS Feed - Change Pin Number to Names for Polarized Capacitor
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Topic: Change Pin Number to Names for Polarized Capacitor
    Posted: 29 Sep 2025 at 1:19pm
Can’t change pin names in polarized capacitor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 1:41pm
What pin names do you want?
Give us an example.
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 7:54pm
P & N
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 8:08pm
In my 51 years in the PCB design industry, I've never seen a EE engineer name capacitor pins P & N in the schematic.
But it could be a new thing that I haven't heard of yet.
In the IPC world, all positive pins are 1 and negative pins are 2.
Pin 1 always on the left.
Diodes are different because there have been too many errors made using pin names 1 & 2. However, many EE engineers use Pins 1 & 2 for diodes. The main problem with diodes is LEDs. The polarity marking on a diode is on the cathode. The polarity marking on many LEDs is on the Anode. Thus comes the confusion.
Renamed pins are saved to the FPX file and there is no provision for saving alpha pin names for capacitors (yet).
Post Options Post Options   Thanks (0) Thanks(0)   Quote m.elsayed Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 58 minutes ago at 3:51am
giving user ability to change numbers 1, 2 to P&N it be more helpful
this option let user use it or not
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 18 minutes ago at 8:31am
Are you saying that EE engineers are putting P & N in capacitor symbols in the schematic?
We don't know any CAD vendor schematic capture tool that provides default polarized capacitor library symbols with P & N pin names.
I've been in the PCB design industry for over 50 years and I've never seen a component manufacturer datasheet for polarized capacitors that used pin names P & N.
Is this something that is unique to your company?
Regardless, we're looking into allowing the user to rename polarized capacitor pin names in the property dialog box.
