  New Posts New Posts RSS Feed - IPC-7251 & 3-Tier PTH Pad Stack Obsolete
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Topic: IPC-7251 & 3-Tier PTH Pad Stack Obsolete
    Posted: 05 Nov 2014 at 10:13am
In 2009 IPC (Dieter Bergman, John Perry and Tom Hausherr) started progress on a land pattern standard for through-hole components called IPC-7251. There were meetings where Gary Ferrari attended by webcast. The 3-Tier pad stack annular ring for through-hole was based off the same precedent for SMD where the Least, Nominal and Most environments had a single value for Toe, Heel and Side. IPC-7251 never got published and progress was discontinued on October 1, 2014 by the IPC 1-13 Land Pattern committee as they decided to instead add it to IPC-7351C which we’re currently working on.
The IPC-7251 through-hole pad stack was inherently flawed due to the 3-Tier annular ring concept that the same Annular Ring Value could be used for any hole size. An example of this would be: The Nominal Environment annular ring (AR) was set to 8 mils. That means that a 10 mil hole had a 8 mil AR and a 20 mil hole had a 8 mil AR and the 40 mil hole had a 8 mil AR and a 80 mil hole had a 8 mil AR. The flaws are apparent in that small holes require small AR and large holes require a larger AR for solder volume, strength, voltage current, heat, etc. Even though LP Wizard and Library Expert supported IPC-7251, the through-hole default in both programs was “Proportional Pad Stacks” due to the fact that IPC-7251 was an unreleased standard.
